Hello from Texas
Dragula
Texas, USA
Just introducing myself. I'm pretty much a newbie to drones.
I just got a Mini 2 and plan to take it to Oahu, Hawaii next week.
I see there are many restrictions to flying there (state parks and beaches) but I'm hoping I can still get some footage of my vacation. I plan on using the B4UFLY app to determine where I can take off or land. Are there any other resources someone can recommend to help keep me out of trouble? :)
Thanks
Hello from the Crossroads of America Dragula
SWEET ! :)
That may take care of the airspace you're flying in, but not the property you will be standing on. They may not allow drone operations from the property. 🤔
Better call saul... ;)
Here's a few links that may help with local drone laws in Hawaii.
Good luck on your research and enjoy your trip.
Welcome to the Forum. :cool:
Greetings from Birmingham Alabama USA, welcome to the forum!
@MA2 317 has given you a lot of information that will help to keep you out of trouble, please take the time the review it, @MA2 317 took the time to research it for you.
Here is my advice, stay out of the Volcanos, if you gotta zoom in one, do it vicariously… Here is a link...
As a New Drone Pilot, there are a couple of Legal Things you may need to do…
If you have not already done so, you will need to get your TRUST Certificate. You can get that at the Pilot Institute Web Site (FREE…) . Your Drone weighs less than 250-grams (0.55 pounds) and if you are flying under The Exception for Recreational Flyers, you are not required to register your Drone.
When I first started flying I registered my Mini 2 because the TRUST Certificate and FAA Registration established me as a "certified" Unmanned Aerial Vehicle (UAV) Pilot. I have now passed my Part 107 License Exam and am awaiting the arrival of my Permanent License and then I will re-register my Mini 2 under Part 107.
If you are considering acquiring your Part 107 License, here is a link to get you going…
Since you live in Texas, there are specific laws and rules for you to follow, please check the link below for all the Rules and Laws that are in effect in your neck of the woods and it also links you to some of the Best Places to Fly in your area… Also, if you travel on vacation, visit friends, and relatives in other parts of the country, check back here so you do not run afoul of the law.
Below is the link to all of the downloads offered by DJI for the Mini 2, including the User Manual.
Happy Droning…
Welcome to the forum.
Please and do be sure you have read our guidelines.
Don't be shy and ask anything if you can't find it by searching . Thumbswayup
Thanks
Welcome to the forum from the Houston area (Pearland)
Welcome to the forum! :)
Welcome to the forum. We look forward to your participation and your view of the world.
Thanks
Welcome to the forum from the beautiful Colorado Rockies! Happy and safe flying!
Dragula, welcome to the forum from Hauptmann in North Texas!
You'll love the flexibility of vantage points an aerial camera platform affords--you'll get shots and videos you could only dream of before! I fly a Mavic 2 Pro now, but will soon be upgrading to the Mini 3 Pro..
Our more than 150,000 members worldwide enjoy helping each other get the most out of our hobby. Many of the questions you'll have will have already been addressed, and are easy to search. New questions? Just ask!
Winds in Hawaii can be pretty fierce. It's best to take off UPWIND, so you don't have to fight them bringing your drone back to your homepoint.
Glad to have you with us!
Rich R (aka Hauptmann)
p.s. Be sure to follow LoudThunder's and GFields' advice.
cjd54
