Hello from the forest city šŸ˜¬, London Ontario!
Welcome from the Hampton Roads area of Virginia, USA. We have a Member's Map in the Upper Right of the Title Bar. Click on "Members" and then Click on "Member's Mapā€¦" Check it out and you might find some new flying friends.
Since you live in Canada, there are specific laws and rules for you to follow, please check to ensure these are current.
And here are the rules about flying your drone in the UKā€¦
Even if you have flown Drones before, here is some Good Old Fashion Adviceā€¦
Plug in your phone/tablet into your controller; turn on the Controller and DJI Fly App (if it does not start on its ownā€¦). On the Drone, open the front legs, then open the back legs, and then remove the Gimbal Cover.
The Gimbal is the most delicate item on the Drone and banging or bumping can damage it. I also fastened a short "Remove Before Flight" ribbon to the cover so it's more noticeable and I do not forget to remove itā€¦
Turn on the drone and watch it come to "life." Watching the Gimbal go through its self-check is almost like watching a puppy or kitten opening its eyes for the first timeā€¦
Place the drone down (preferably on a Landing Pad) while it finishes its self-test (collecting satellites, etcā€¦).
Lift off, 6 feet (2-meters) or so, hover a bit, check the controls (move the drone a bit forward, back, left, right, yaw left and right). By now, your Controller will probably report again, "Home point Updated."
If you go out in a rush and race thru your start up and take off before the drone has finished it prep, it may update its Home Point over that pond or that old tree you are flying over and in your excitement, you'll fly the drone long past it Low Battery point and when it engages Return to Home and lands in the pond or in a tree; it will be all on youā€¦
Below is the link to all of the downloads offered by DJI for the Mini 3 Pro, including the User Manual.
After you read the Manual, read it again, you will be surprised what you missed the first time and you will be better prepared for that first "scary momentā€¦"
Fly On and Fly Safeā€¦
Wow, really appreciate the detailed response. Definitely spending the next wee while watching YouTube videos to get as much info as possible.
Thanks again
Currently researching where Iā€™m allowed to fly it!
That one's easy:
Use the menu to pick <250g for the class of drone.
Integrated into my favourite drone app, which also pulls in NOTAMs and marks the DJI flight restrictions as well.
I assume you've already bookmarked the Transport Canada site, but in case:
That one's easy:
Amazing, thanks!
Reactions: LoudThunder
Welcome to the forum! :)
Photogeezer
