Hello from the Netherlands
Hello from the Crossroads of America mszulen.
Nice to meet you Marek. 🤝
Welcome to the Forum. :cool:
Welcome to the forum.
Please and do be sure you have read our guidelines.
Don't be shy and ask anything if you can't find it by searching . Thumbswayup
Greetings from Birmingham Alabama, welcome to the forum!
I’m not new to drones (fpv since a few years) and rc planes (for over 30 years), but new to DJI.
Since 2 weeks (still) happy owner of Mini 3 Pro.
Welcome from the Hampton Roads area of Virginia, USA. We have a Member's Map in the Upper Right of the Title Bar.
Since you live in the Netherlands, there are specific laws and rules for you to follow, please check to ensure these are current.
Even though you have experience with other types of drones, you have a new baby now and it demands different care, here is some Good Old Fashion Advice…
Below is the link to all of the downloads offered by DJI for the Mini 3 Pro, including the User Manual.
Happy, Safe and Legal Droning…
Welcome to the forum! :)
Reactions: GFields
Pleopard
