New to the drone community
Welcome to the forum! :)
A few useful things to get you started:
Not sure if the M4Pro is like the M3Pro or Mav 3 Classic, but mine always boot up in Normal , no matter where you have the controller set to. So if you want to slow it down you have to switch out of cine and back to cine. Also if you go through weeks without using, always store your batteries around 50%. Not storing for any length of time at 80 % or higher or less than 20 % will greatly extend the life of these expensive intelligent batteries.
Welcome to the forum. We look forward to your participation and your view of the world.
I’m a new DJI Mini 4 Pro owner from the Charlotte, NC area.
As a New Drone Pilot, there are a couple of Legal Things you may need to do…
If you have not already done so, you will need to get your TRUST Certificate. You can get that at the Pilot Institute Web Site (FREE…). Your Drone weighs less than 250-grams (0.55 pounds), and while you are flying under The Exception for Recreational Flyers, you are not required to register your Drone.
FAA TRUST Online Portal for Recreational Drone Operators - Pilot Institute
Get your FAA TRUST Certificate of Completion to legally fly drones for recreational reasons in the United States.
trust.pilotinstitute.com trust.pilotinstitute.com
If you are considering acquiring your Part 107 License, here is a link to get you going…
Since you live in South Carolina, there are specific laws and rules for you to follow, please check the link below for all the Rules and Laws that are in effect in your neck of the woods and it also links you to some of the Best Places to Fly in your area… Also, if you travel on vacation, visit friends, and relatives in other parts of the country, check back here so you do not run afoul of the law.
Lift off, 6- feet (2-meters) or so, hover a bit, check the controls (move the drone a bit forward, back, left, right, yaw left and right). By now, your Controller will probably report again, Home point Updated.
Below is the link to all of the downloads offered by DJI for the Mini 4 Pro, including the User Manual.
Fly On and Fly Safe…
Hello, I’m a new DJI Mini 4 Pro owner from the Charlotte, NC area. I’ve been doing photography for a little over a year and decided to get a drone because why not.
That was what got me into flying drones. I've been a photographer for decades, and instead of buying a new lens, I thought that it was time to use a drone to capture vistas I can't see from the ground and reach areas I couldn't on foot.
Enjoy!
Keith J
