Hello from the outskirts of Copenhagen - Denmark
Hello from the Crossroads of America herodk.
Good choice for the first one. 👍
Have fun, fly safe, and welcome to the Forum. :cool:
Welcome to the forum.
Please and do be sure you have read our guidelines.
Don't be shy and ask anything if you can't find it by searching . Thumbswayup
Hi,
First time drone owner here. Bought the Mini 3 Pro mostly for doing photography. So far really impressed with the little thing!
Hello and welcome to the forum from the Colorado Rocky Mountains! Happy and safe flying!
Welcome from the Hampton Roads area of Virginia, USA. We have a Member's Map in the Upper Right of the Title Bar.
Since you live in Denmark, there are specific laws and rules for you to follow, please check to ensure these are current.
Now, for some Good Old Fashion Advice…
Below is the link to all of the downloads offered by DJI for the Mini 3 Pro, including the User Manual.
Happy, Safe and Legal Droning…
Greetings from Birmingham Alabama, welcome to the forum!
Welcome to the forum! :)
PilotOne
