Hello from Tuolumne County California
rotaur
Sonora, California
My name is Gerald and I have the DJI Mini 4 pro which I bought about 4 months ago. Yesterday when I was folding the arms back in, the glue joint on the right rear arm broke loose. There is no damage, and it has never been crashed or even landed hard. I looks to me like the original glue was never adhered image.jpgwell. Does anyone know what is the best glue to use on this or even what kind of glue DJI uses for this?
firstly welcome to the forum
sorry to hear about the defective arm joint on your drone ,it is definately something that should fall under a warranty repair
As a New Drone Pilot, there are a couple of Legal Things you may need to do…
If you have not already done so, you will need to get your TRUST Certificate. You can get that at the Pilot Institute Web Site (FREE…). Your Drone weighs less than 250-grams (0.55 pounds), and while you are flying under The Exception for Recreational Flyers, you are not required to register your Drone.
FAA TRUST Online Portal for Recreational Drone Operators - Pilot Institute
Get your FAA TRUST Certificate of Completion to legally fly drones for recreational reasons in the United States.
trust.pilotinstitute.com trust.pilotinstitute.com
If you are considering acquiring your Part 107 License, here is a link to get you going…
Since you live in California, there are specific laws and rules for you to follow, please check the link below for all the Rules and Laws that are in effect in your neck of the woods and it also links you to some of the Best Places to Fly in your area… Also, if you travel on vacation, visit friends, and relatives in other parts of the country, check back here so you do not run afoul of the law.
Lift off, 6- feet (2-meters) or so, hover a bit, check the controls (move the drone a bit forward, back, left, right, yaw left and right). By now, your Controller will probably report again, Home point Updated.
Below is the link to all of the downloads offered by DJI for the Mini 4 Pro, including the User Manual.
Fly On and Fly Safe…
Hello from the Crossroads of America rotaur.
Nice to meet you Gerald. 🤝
Welcome to the Forum. :cool:
Welcome to the forum. We look forward to your participation and your view of the world. Yes, as others have said,, contact DJI.
Nice to meet you LoudThunder and Thank You for the tips and advice, I do appreciate it!
Reactions: LoudThunder
cjd54
