Hello from Utah!
Greetings from Birmingham Alabama, welcome to the forum!
Welcome to the forum. We look forward to your participation and your view of the world.
Welcome to Mavic Pilots .
Don't be shy and ask anything if you can't find it by searching
and stay safe.. Thumbswayup
Welcome from the Hampton Roads area of Virginia, USA. I fly a Mini 2 and I know the excitement you are going through…
If you are in the U.S.A. there are a couple of Legal Things you need to do… Register your Drone; that can be done at the FAA Web Site. You also need to get your TRUST Certificate. You can get that at the Pilot Institute Web Site (FREE…) .
FAADroneZone
FAA TRUST Online Portal for Recreational Drone Operators - Pilot Institute
Below is the link to all of the downloads offered by DJI for the Mavic Air 2. You will also find the 57-page User Manual, in case your Drone did not come with one. The User Manuals are published in different languages.
https://dl.djicdn.com/downloads/Mavic_Air_2/Mavic_Air_2_User_Manual_v1.6_enIII.pdf
Happy and Safe Droning…
Welcome to the forum! :)
Hello from Minnesota and welcome to the Forum....Congratulations on your Mavic Air 2....There's a lot of good quality teaching/feedback going on in here. Just ask, and the experts are great on providing good sound advice for you to apply and use... Remember to always Fly safe, Fly Smart and keep the drone in sight.
Reactions: Skywatcher2001
Joe Duhr
