Hello from Ventura, CA
trevor1030
Ventura
Hi all haven’t had a drone since the Mavic 2, something made me want to get back into it and I went ahead and bought the air 3! I was very close to getting the mini 3 pro but since we have so much wind here, I opted to spend the extra money for a little better drone and little more weight. If there are any clubs or anything in the Ventura county area I’d love to know!
Thanks
Trevor
Welcome to the forum! :)
Hello from the Crossroads of America trevor1030.
Nice to meet you Trevor. 🤝
Welcome to the Forum. :cool:
Since you are a returning Drone Pilot, there are a couple of Legal Things you may need to do…
If you have not already done so, you will need to get your TRUST Certificate. You can get that at the Pilot Institute Web Site (FREE…) . Your Drone weighs more than 250-grams (0.55 pounds) and while you are flying under The Exception for Recreational Flyers, you are required to register your Drone.
If you are considering acquiring your Part 107 License, here is a link to get you going…
Since you live in California, there are specific laws and rules for you to follow, please check the link below for all the Rules and Laws that are in effect in your neck of the woods and it also links you to some of the Best Places to Fly in your area… Also, if you travel on vacation, visit friends, and relatives in other parts of the country, check back here so you do not run afoul of the law.
Lift off, 6- feet (2-meters) or so, hover a bit, check the controls (move the drone a bit forward, back, left, right, yaw left and right). By now, your Controller will probably report again, Home point Updated.
Below is the link to all of the downloads offered by DJI for the Air 3.
After you read all the material, read it again, you will be surprised what you missed the first time and you will be better prepared for that first "scary moment…"
Fly On and Fly Safe…
charliesunique
