Hello newbie from N.W. In.
yuke
N.W. In.
Hello this is my 1st drone was purchased at Costco and hope to fly it Christmas day with my S-10e phone was told by member motorcycle rider it would work with this phone even though customer support said they did not try it out yet sure hope rider is right if any one else is using the s10e please chime in and verify . Thanks cant wait to get this up in the air and exploring and flying.
Welcome to the forum.
Don't be shy and ask anything if you can't find it by searching .Thumbswayup
WELCOME to the forum :)
Hello 317 maybe sometime we could get together and you could teach me how to fly this mini 1. I am 46304 at the tip of Lake Michigan.
Welcome Back… from the Hampton Roads area of Virginia, USA. We have a Member's Map in the Upper Right of the Title Bar. Click on "Members" and then Click on "Member's Map…" Check it out and you might find some new flying friends.
As a Semi-New Drone Pilot, there are a couple of Legal Things you may need to do…
If you have not already done so, you will need to get your TRUST Certificate. You can get that at the Pilot Institute Web Site (FREE…) . Your Drone weighs less than 250-grams (0.55 pounds) and while you are flying under The Exception for Recreational Flyers, you are not required to register your Drone.
When I first started flying I registered my Mini 2 because the TRUST Certificate and FAA Registration established me as a "certified" Unmanned Aerial Vehicle (UAV) Pilot.
If you are considering acquiring your Part 107 License, here is a link to get you going…
Since you live in Michigan, there are specific laws and rules for you to follow, please check the link below for all the Rules and Laws that are in effect in your neck of the woods and it also links you to some of the Best Places to Fly in your area… Also, if you travel on vacation, visit friends, and relatives in other parts of the country, check back here so you do not run afoul of the law.
Perhaps you can find some flying buddies to help you learn to fly but in the meantime, even if you have flown Drones before, here is some Good Old Fashion Advice…
Below is the link to all of the downloads offered by DJI for the Mini, including the User Manual.
Fly On and Fly Safe…
Sathwik
