Hello , rookie here from south alabama area
roadhammer
Mobile, AL, USA
Hello everyone rookie here from South Alabama area with a Mavic 2 pro and buddy I haven't even taken it out of the box and having issues , so apparently DJI has quit manufacturing accessories for the Macic 2 so is used the only place to find accessories? Also anyone have issues with the Dji go 4 app not saving your user name ?
Greetings from Birmingham Alabama USA, welcome to the forum!
You can get accessories just about everywhere, just Google it.
You may need to remove the DJI Go 4 app and reinstall it
Hello from the Crossroads of America roadhammer.
Sorry I can't help you with your situation.
Hopefully you'll get it sorted out soon.
But I can welcome you to the Forum. 😎
Thank you very much
Welcome to the forum.
Please and do be sure you have read our guidelines.
Don't be shy and ask anything if you can't find it by searching . Thumbswayup
So does anyone know if the Smart controller is compatible with my Mavic 2 pro ?
I think so... 🤔
Here's a link to DJI's Smart Controller that will work with OcySync 2.0 systems.
And this DJI link shows the Mavic 2 having the OcuSync 2.0
I am sorry that I cannot offer any advice concerning your problem, but when it is resolved, you need this as a Rookie…
As a New Drone Pilot, there are a couple of Legal Things you may need to do…
If you have not already done so, you will need to get your TRUST Certificate. You can get that at the Pilot Institute Web Site (FREE…) . If your Drone weighs less than 250-grams (0.55 pounds) and you are flying under The Exception for Recreational Flyers, you are not required to register your Drone.
I registered my Mini 2 because the TRUST Certificate and FAA Registration established me as a "certified" Unmanned Aerial Vehicle (UAV) Flyer.
If you are considering acquiring your Part 107 License, here is a link to get you going…
Since you live in Alabama, there are specific laws and rules for you to follow, please check the link below for all the Rules and Laws that are in effect in your neck of the woods and it also links you to some of the Best Places to Fly in your area… Also, if you travel on vacation, visit friends, and relatives in other parts of the country, check back here so you do not run afoul of the law.
Below is the link to all of the downloads offered by DJI for the Mavic 2 Pro/Zoom, including the User Manual.
Happy Droning…
Suilven
