Hey from Ukraine/Ireland
Greetings from Birmingham Alabama, welcome to the forum!
Welcome to the forum.
Please and do be sure you have read our guidelines.
Don't be shy and ask anything if you can't find it by searching . Thumbswayup
Hey, fairly recently relocated to Ireland, here's a video of my home city, Kyiv, that my friend and I filmed back in the day. Got my Mavic Mini 2
Welcome from the Hampton Roads area of Virginia, USA. We have a Member's Map in the Upper Right of the Title Bar.
What a sad, sad video you shared, I am so sorry. But you are now in Ireland and I hope things are looking up for you. Just remember, you are as different to them as they are different to you…
Since you live in Ireland, there are specific laws and rules for you to follow, please check to ensure these are current.
Even though you have flown Drones before, here is some Good Old Fashion Advice…
Below is the link to all of the downloads offered by DJI for the Mini 2, including the User Manual.
Happy, Safe and Legal Droning…
Hey, fairly recently relocated to Ireland, here's a video of my home city, Kyiv, that my friend and I filmed back in the day:
Got my Mavic Mini 2 and want to ask you guys here a ton of questions on getting better at it! :D
Thank you everyone for such a warm welcome!!
LoudThunder, thanks for this long post! Quick question if I may: do I need to register as a drone pilot if I only have Mini 2 (under 250g)? I see the clause re camera, does it mean that, if I have a camera on my drone, I have to register regardless of its weight?
Thanks!
Welcome to the forum! :)
I am located in the U.S.A. and not in Ireland. I cannot answer any questions concerning what it entails to fly legally in Ireland. Here are some more web sites to better explain the requirements. The top on is directly to the Irish Aviation Authority, and they are responsible for the management of Irish controlled airspace, the safety regulation of Irish civil aviation and the oversight of civil aviation security in Ireland.
Below are various Drone flying clubs and Organizations that you might be able to call visit or call directly on the phone and I'm sure they would welcome an new Drone Flyer…
Now, the following link is not meant to scare you but the Irish Authorities are serious about stupid drone flyers…
Good Luck and Safe Droning…
AVI Drones
