Hi From Alberta, Canada/ Cabarette Dominican Republic
New to the wonderful world of drones flying an Air 2S pilot with RC Pro controller as well as Mini 2
Welcome from the Hampton Roads area of Virginia, USA. I fly a Mini 2 and I know the excitement you are going through…
We have a Member's Map in the Upper Right of the Title Bar, Tap "Members", Tap "Member's Map" Members map
Here is a link to the laws and rules for flying your Drones in Canada.
Now, for some Good Old Fashion Advice…
Plug in your phone/tablet into your controller; turn on the Controller and DJI Fly App (if it does not start on its own…). On the Drone, open the front legs, then open the back legs, and then remove the Gimbal Cover.
The Gimbal is the most delicate item on the Drone and banging or bumping can damage it. I also fastened a short "Remove Before Flight" ribbon to the Gimbal Cover so it's more noticeable and I do not forget to remove it…
Turn on the Drone and watch it come to "life." Watching the Gimbal go through its self-check is almost like watching a kitten or puppy opening its eyes for the first time…
Place the Drone down (preferably on a Landing Pad) while it finishes its self-test (collecting satellites, etc…).
Check your battery status (Phone, Drone, and Controller), check the Signal Strength (5-Bars), number of satellites (at least 10) and by now the Controller should have reported it updated the Home Point.
If you go out in a rush and race thru your start up and take off before the drone has finished it prep, it may update its Home Point over that pond or that old tree you are flying over and in your excitement, you'll fly the drone long past it Low Battery Point and when it engages Return to Home and lands in the pond or in a tree; it will be all on you…
Now go have fun, learn to fly the Drone by sight before you try to fly it out a distance depending on the video feed, first-person view (FPV).
Below is the link to all of the downloads offered by DJI for the Mini 2. You will also find the 75-page User's Manual.
DJI Mini 2 - Download Center - DJI
And here is the link to all of the downloads offered by DJI for the Air 2S. You will also find the 57-page Air 2S's User Manual.
Happy and Safe Droning…
Greetings from Birmingham Alabama, welcome to the forum!
Welcome to the forum.
Please and do be sure you have read our guidelines.
Don't be shy and ask anything if you can't find it by searching . Thumbswayup
Welcome to the forum! :)
Welcome from the Pacific Northwest and to the addiction. I also have the Mini 2 and Air 2S. I've learned a lot from this forum and I'm sure you will too.
I was in the beautiful province of Alberta last Oct '21. Took my Mini 2 with me but couldn't fly due to the unrelenting wind.
Looking forward to learning from and interacting with everyone here
Welcome to Mavic Pilots from Dayton Ohio USA! Fly safe and have fun!
Tgbell
