Hi from Austria, Europa!
Captain Filmmaking
Austria
Hi Guys!
I‘m new not just to drones, but also to filmmaking. I was quite a bit unsure, if a little drone like the Mini 3 will do the job for both bikepacking and also delivering adequate picture quality. So I‘m still learning how to use it best and looking forward for some helpful tips and feedback! :)
So what do think about my first mini 3 clip!?
greetings from Austria,
FerdinandS
Hi Guys!
FerdinandS
This was awesome. Great job. We need you to come to the 3rd Annual South Florida Drone Meetup in Jensen Beach, FL on April 1, 2023. You could win the Best Video Award.
Welcome to the forum. We look forward to your participation and more of your view of the world.
Greetings from Birmingham Alabama, welcome to the forum!
Hi Guys!
FerdinandS
Welcome to the forum from the mountains of Colorado! Visiting Austria has been on my bucket list for years! Happy and safe flying!
Welcome from the Hampton Roads area of Virginia, USA. I fly a Mini 2 and I know the excitement you are going through…
We have a Member's Map in the Upper Right of the Title Bar, Tap "Members", Tap "Member's Map" Members map
Living in Austria, be sure you are following all of the laws and rules applicable to you. Here is a Link to start you off…
Drone Laws in Austria [Updated April 14, 2022]
Now, for some Good Old Fashion Advice…
Plug in your phone/tablet into your controller; turn on the Controller and DJI Fly App (if it does not start on its own…). On the Drone, open the front legs, then open the back legs, and then remove the Gimbal Cover.
The Gimbal is the most delicate item on the Drone and banging or bumping can damage it. I also fastened a short "Remove Before Flight" ribbon to the Gimbal Cover so it's more noticeable and I do not forget to remove it…
Turn on the Drone and watch it come to "life." Watching the Gimbal go through its self-check is almost like watching a kitten or puppy opening its eyes for the first time…
Place the Drone down (preferably on a Landing Pad) while it finishes its self-test (collecting satellites, etc…).
Check your battery status (Phone, Drone, and Controller), check the Signal Strength (5-Bars), number of satellites (at least 10) and by now the Controller should have reported it updated the Home Point.
If you go out in a rush and race thru your start up and take off before the drone has finished it prep, it may update its Home Point over that pond or that old tree you are flying over and in your excitement, you'll fly the drone long past it Low Battery Point and when it engages Return to Home and lands in the pond or in a tree; it will be all on you…
Now go have fun, learn to fly the Drone by sight before you try to fly it out a distance depending on the video feed, first-person view (FPV).
Below is the link to all of the downloads offered by DJI for the Mini 3 Pro. You will also find the 74-page Mini 3 Pro's User Manual.
Happy and Safe Droning…
Welcome to the forum! :)
Please and do be sure you have read our guidelines.
Don't be shy and ask anything if you can't find it by searching . Thumbswayup
PilotOne
