Hi all,
Brand new drone owner/flyer, looking to soak up advice from you "old guys/gals"
Seen lots of info on here already!!
Welcome to the forum from the Rocky Mountains of Colorado! Happy and safe flying!Hi all,
Hey Chief,Welcome from the Hampton Roads area of Virginia, USA.
Living in the UK means there are lots of rules and regulations, be sure you are following all of the laws and rules applicable to you. Here is a DJI Link to Many Sites of interest to all, even those in the U.S.A.
Drone Flight Application Strategy Digest, continually updated!
You did not say what you are flying, if it's DJI, let us know the model and I'll send you the link to the User manual. In the mean time…
Once again, what are you flying?
Happy and Safe Droning…
DJI Mavic Mini "mach I"
LOL,I did a Google search and I could not find a reference to a DJI Mavic Mini "mach I". So I do not know it that just means your little baby has "Racing Stripes" on it or something more…
Any case, below is the link to all of the downloads offered by DJI for the Mavic Mini. You will also find the 49-page Mavic Mini's User Manual, in case your Drone did not come with one.
Be Safe, Be Legal, Have Fun…
LOL,
I may (or may not?) have coined the "mach 1" portion. Just to differentiate form the 2, 3, SE etc.
Maybe I should have said Mini Originale
Thanks again.
