Hi from Dorset
Now bought a Mini 2.
Since you live in the UK, there are specific laws and rules for you to follow, please check to ensure these are current.
Even if you may have flown Drones before, here is some Good Old Fashion Advice…
Below is the link to all of the downloads offered by DJI for the Mini 2, including the User Manual.
Fly On and Fly Safe…
Hi from Sturminster Newton, Dorset, UK and I'm 75 years old but amazingly still have most of my faculties! Started with a Snaptain SP650 for £20 and had a lot of fun. Now bought a Mini 2.
I'm 56 and amazingly still have MY faculties, also! ha!
Welcome from Savannah, GA! I loved my Mini 2. I now have a Mavic 3 and love that, too! Imagine that..
Welcome to you Joesher, from Houston, Texas. Keeping all of your faculties is a good thing. 😁
i will be 76 next Tuesday and although i still have most of my faculties ,the problem is trying to communicate that fact to the rest of my body ,which doesn't seem to want to do the things ,that my brain is telling it to do
Welcome to the forum! :)
Here are some things to help you get started with your drone:
  • Download the DJI manual for your drone here (it doesn't come in the box). The manual is packed with lots of useful tips and will give you a better understanding of your drone's features.
  • Check out this getting started guide for some tips not found in the DJI manual.
  • Your drone batteries will last longer if you use and maintain them like this.
  • Practice flying outdoors in a wide open location that's free of all obstacles. Don't attempt to fly inside your house or in other confined locations.
  • The drone records flight data each time you fly. You can decrypt and view those flight logs with these tools.
  • Check out MavicHelp.com for commonly used accessories you might need.
Hi from South Wales, hope you enjoy the forum, cheers Len
xa_
