Hi from East Kent
jimages
Canterbury, UK
Hi, I'm just here to say hello, I have owned a drone for a couple of years, but was reluctant to fly it because the rules seemed a bit too restrictive, but have just bought a Mini 2, a have flown it more in the last month, than I flew my Mavic pro in 2 years.
I am more into photography than video, mainly because I have not really got the hang of editing, or even creating nice footage yet.
I must say, I love the mini 2, it is just as capable as my Mavic pro, but so much more convenient in every way.
Welcome from the Hampton Roads area of Virginia, USA. We have a Member's Map in the Upper Right of the Title Bar. Check it out and you might find some new flying friends.
Since you live in the UK, there are specific laws and rules for you to follow, please check to ensure these are current.
Even if you may have flown Drones before, here is some Good Old Fashion Advice…
Below is the link to all of the downloads offered by DJI for the Mini 2, including the User Manual.
Happy Droning…
Happy Droning…
Thank you for the welcome, and sage advice, along with the links :)
Welcome to the forum.
Please and do be sure you have read our guidelines.
Don't be shy and ask anything if you can't find it by searching . Thumbswayup
Greetings from Birmingham Alabama USA, welcome to the forum!
Welcome to the forum! :)
hcastro
