Hi from Essex in UK. New Mavic Mini 3 Pro owner
Welcome to the forum.
Don't be shy and ask anything if you can't find it by searching . Thumbswayup
Greetings from Birmingham Alabama, welcome to the forum!
Really happy with my purchase and i enjoy flying my new toy.
Welcome from the Hampton Roads area of Virginia, USA. We have a Member's Map in the Upper Right of the Title Bar.
Since you live in UK, there are specific laws and rules for you to follow, please check to ensure these are current.
Even if you may have flown Drones before, here is some Good Old Fashion Advice…
Below is the link to all of the downloads offered by DJI for the Mini 3 Pro, including the User Manual.
Happy, Safe and Legal Droning…
Welcome to the forum! :)
Reactions: GFields
Thanks for the warm welcome all. Can I ask a quick question here? If using a laptop for editing what kind of spec is required and what software do you recommend?
One with a fast processor and a lot of RaM
Daly_mail
