Welcome from the Hampton Roads area of Virginia, USA. I am a
Mini 2 Flyer and I know the excitement of flight. So, if I may offer some advice.
I would also advise you to use YouTube and watch a lot of the Videos on flying and setting up the
Mini 2. When it is too dark, too cold, or too wet, you can "fly it vicariously" through YouTube. Also watch some of the Blooper Drone Videos and learn how not to fly your "New Baby."
Below is the link to all of the downloads offered by DJI for the Mavic Mini. You will also find the 49-page Mavic Mini's User Manual, in case your Drone did not come with one.
At DJI Download Center, Learn aboutMavic Mini
www.dji.com
Happy Droning
