Hi from North Queensland.
Suzygs1000
Ingham 4850 Australia
Hi, I am getting a bit aged, and have been flying rc planes for many years, also FPV drones. Just purchased a Mavic Mini, and have now got it sorted out, sorta ... I fly mainly at the Ingham Airport, which is an unregulated strip, but an authorised zone. I have finally worked out how to get authority and have made my first video of a flight over Ingham, farthest distance 1.3 kms. Even tho the Mini is only 2.7k, it is a really good picture. I was considering upgrading to a Mini 2, but for the time being, the Mini seems to be quite satisfactory ... cheers to all, Dave.
Welcome to the forums Dave. You don’t always have to have the latest and greatest and I’m sure you’ll surprise yourself and others with the Mini. Next step is video editing and a Youtube channel 😝
Greetings from Birmingham Alabama, welcome to the forum!
Hi Dave
Thanks for sharing. As a “banana bender” can you confirm you are able to fly in National Parks in QLD if you comply with common sense rules on people and wildlife etc. planning a caravan trip from Perth in the near future.
Welcome to the forum.
Don't be shy and ask anything if you can't find it by searching . Thumbswayup
Hi Dave
I can confirm that, yes you certainly can, and I often do so.
QLD, like WA (and NT) are very drone friendly.
Welcome from the Hampton Roads area of Virginia, USA. I fly a Mini 2, but your Mini is a keeper…
We have a Member's Map in the Upper Right of the Title Bar, Tap "Members", Tap "Member's Map" Members map
This is the DJI Forum link on flying a Drone in Australia…
#Dronestrategy Australia
And here are the Drone Laws…
And of course the official Australian Government rules and laws…
https://www.casa.gov.au/knowyourdrone/drone-rules
Below is the link to all of the downloads offered by DJI for the Mavic Mini. You will also find the 49-page Mavic Mini's User Manual, in case your Drone did not come with one.
Happy and Safe Droning…
instaproapk
