Hi from Spain!
Welcome to the forum! :)
Hello from the Crossroads of America rbn88am
Welcome to the Forum. :cool:
Welcome to the forum. We look forward to your participation and your view of the world.
I'm from Spain and I'm starting in the world of the drone. I have Air2S Mini3Pro and Mavic3Classic
Since you live in Spain, there are specific laws and rules for you to follow, please check to ensure these are current.
You saidn you were starting out in the world of drones so,. Even if you may have flown Drones before, here is some Good Old Fashion Advice…
Below is the link to all of the downloads offered by DJI for the Mini 3 Pro, the A2S, and the N3, including the User Manuals.
Fly On and Fly Safe…
cjd54
