already have my TRUST certificate even before Amazon delivers my DJI
Mini 3 Pro
Welcome from the Hampton Roads area of Virginia, USA. We have a Member's Map in the Upper Right of the Title Bar.
mavicpilots.com
Congrats on getting all the legal stuff out of the way, but since you live in Florida, there are specific laws and rules for you to follow, please check to ensure these are current.
Drones are allowed in Florida for recreational and commercial use, subject to FAA and local regulations. Read on for details.
drone-laws.com
Now, for some Good Old Fashion Advice…
When you do get your own drone, do not let the excitement of the moment get the best of you. When you are going out to fly, do it slowly and deliberately. Get used to a set procedure and even practice it.
Below is the link to all of the downloads offered by DJI for the
Mini 3 Pro, including the User Manual.
At DJI Download Center, Learn aboutDJI
Mini 3 Pro
www.dji.com
Happy, Safe and Legal Droning…
