Hi from Surrey UK
Adam_C
Farnham, UK
Hi all, just joined, hope to find some good info and maybe contribute something...
Got my Mavic Mini 3 Pro today - charged it, updated it, bought the Care Refresh package, took it out to the patio, removed that little piece of foam from behind the gimble and...
... the Farnborough Airshow No Fly Zone activated this morning until the 24th... Gaahh!
Greetings from Birmingham Alabama, welcome to the forum!
welcome to the forum ,wouldn't you just know it ,its air show season
if you get the CAA sky wise App ,you will see just how many TFRs there are now, and in the coming weeks, sods law at work
Welcome to the forum.
Please and do be sure you have read our guidelines.
Don't be shy and ask anything if you can't find it by searching . Thumbswayup
Welcome to Mavic Pilots from Dayton Ohio USA! Fly safe and have fun!
Welcome from the Hampton Roads area of Virginia, USA. We have a Member's Map in the Upper Right of the Title Bar.
Since you live in the Uk, there are specific laws and rules for you to follow, please check to ensure these are current.
Now, for some Good Old Fashion Advice…
Below is the link to all of the downloads offered by DJI for the Mini 3 Pro, including the User Manual.
Happy, Safe and Legal Droning…
Welcome to the forum! :)
PilotOne
