Hi from the Sunshine Coast mini 2)
Welcome from the Hampton Roads area of Virginia, USA. I am a Mini 2 Flyer and I know the excitement of flight. So, if I may offer some advice.
Below is the link to all of the downloads offered by DJI for the Mini 2. You will also find the 75-page User's Manual, in case your Drone did not come with one. The User Manuals are published in different languages.
DJI Mini 2 - Download Center - DJI
Happy and Safe Droning
Welcome to the forum.
Don't be shy and ask anything if you can't find it by searching .👍👍
Thank you. Excellent advice, which I am following. I printed the manual and am absorbing it. Going to love this little machine I think.
Welcome to the forum! :)
DaleUt.
