Learning the
Mini 3 in the UK.
mavicpilots.com
Since you live in the UK, there are specific laws and rules for you to follow, please check to ensure these are current.
Find out what you need to know and do when you fly drones or model aircraft in the UK
register-drones.caa.co.uk
Even if you may have flown Drones before, here is some Good Old Fashion Advice…
Below is the link to all of the downloads offered by DJI for the
Mini 3, including the User Manual.
At DJI Download Center, Learn aboutDJI
Mini 3
www.dji.com
Happy Droning…
