Newbie UK user - have I landed in the right place?
busadude
uk
Hi all…
So I’m a newbie (will be after the 25th:) and from the UK
Have I landed in the right place for UK residents?
Looking to find out more in the regulations and laws before my maiden flight 😁
Are there other UK users here?
Looking forward to hearing back.
Andy
We have many users from the UK. I'm sure you'll find any help you need here.
if you go on the CAA website you can learn all about when, where, and what things you need to do to fly within the current rules and regs
Since you live in the UK, there are specific laws and rules for you to follow, please check to ensure these are current.
Plug in your phone/tablet into your controller; turn on the Controller and DJI Fly App (if it does not start on its own…). On the Drone, open the front legs, then open the back legs, and then remove the Gimbal Cover.
Lift off, 6 feet (2-meters) or so, hover a bit, check the controls (move the drone a bit forward, back, left, right, yaw left and right). By now, your Controller will probably report again, "Home point Updated."
Fly On and Fly Safe…
Thanks for joining us @ MP! Great having you.
Go up to the top navigation bar, click on members. In another bar, there is a member map. Click on that (may take a bit to load). Once the map is up, if it isn't already showing the UK, move it to the UK. It will show many members there. Some may be near you.
Hi all…
Andy
Welcome to the forum from the beautiful Rocky Mountains of Colorado! Happy and safe flying!
lucian
