I have permanently saved panos (spheres and super-res) as well as videos and pics on my
Goggles RE.
Ive never done the moving of SD card from AC to
Goggles before so not sure about that, however, the
Goggles/AC do store pano files in a not very intutive way, so I had trouble trying to move files to the SD card on a computer, and then inserting in the
Goggles, myself.
So I never went that route again.
The below method is, imo, the best way to view files on the
Goggles, and if downloaded, as I show how, you never need the AC to be on or to move SD cards.
• Insert micro SD card into
goggles, that you will keep there permanently. (Format card via
goggles menu)
• Make sure your default storage location, in
Goggles, is the SD card.
• Whether your using the
goggles during flight, or not, does not matter.
• Once your done shooting Pano (or any other file - Note that the larger the file, the longer the time for trxfr. Panos are very fast. ie: 10sec), In the
Goggles menu, go into the 'playback' menu
• Within 'playback' (while both AC &
Goggles are on - it can be airborne, but recommend it be grounded, as the trxfr takes time, as well as its distracting from flight awareness). You choose 'aircraft' then find whichever file your looking for...
》At this point, you can either view the file/pano momentarily, as long as AC is on, and AC SD has file onboard - OR - You can wirelessly download it from your AC storage to your
Goggles SD card. (It will only copy it, not move it, so itll remain on AC SD card afterwards)
• To view, just single tap the touchpad.
• To download, Swipe downword with 2 fingers (maybe 1?) and youll see 2 symbols (one an arrow and the other trash can).
• The Arrow will download that file from AC to the
Goggles SD card.
• Once download started, youll see a bar on bottom with %.
After this is done, youll be able to access any of those files that youve downloaded to the
Goggles.
I also imagine that after youve transfered one file of each type (video, pic, pano) that you can remove the
Goggles SD card, look at its contents on a computer, and see what location to transfer like files to, as you mentioned before, but keep in mind that panos are generally stitched together via proprietary sw, so it may not accept just any set of images, but pics and vids should be no prob? Just guessing on that.
I FULLY RECOMMEND downloading ALL of your Panos to
Goggles but most of all the SHPERE PANOS are excellent on the
DJI Goggles. and a great show item to show your friends and loved ones!
Hope this helps.
