HoozierDroneDaddy
- Joined
- Mar 12, 2017
- Messages
- 826
- Reactions
- 539
- Age
- 71
If your fortunate enough to have another drone that is capable you can lift the stranded drone down. I made a releasable grappling hook for my Typhoon H to lift a drone from the top of a 90 foot tree. Releasable in case the hook gets caught in the trees or is unable to pull the first drone out, then you can still bring the recovery drone back down.
If it is a situation where the branch needs to be jerked around to release the drone, I have also used it to anchor a 100lb fishing line on the ground, lift the spool over the branch and release it. The spool then falls to the ground on the other side of the branch. If it is a small branch that the fishing line can handle all is ok. If it is a larger branch, then the fishing line is used to pull a rope over the branch.
Glad all the above were able to recover they birds.
