Howdy From North Texas
Hello from the Crossroads of America TX Steve.
Welcome to the Forum. :cool:
I am new to drones
So, I guess you like doing things in Three… a Mini 3, a Mavic 3, and a "3rd" drone… But, still as a New Drone Pilot, there are a couple of Legal Things you may need to do…
If you have not already done so, you will need to get your TRUST Certificate. You can get that at the Pilot Institute Web Site (FREE…). Your Mini 3 weighs less than 250-grams (0.55 pounds), and while you are flying under The Exception for Recreational Flyers, you are not required to register your Drone. However, your Mavic 3 witll have to be registered…
FAA TRUST Online Portal for Recreational Drone Operators - Pilot Institute
Get your FAA TRUST Certificate of Completion to legally fly drones for recreational reasons in the United States.
trust.pilotinstitute.com trust.pilotinstitute.com
If you are considering acquiring your Part 107 License, here is a link to get you going…
Since you live in Texas, there are specific laws and rules for you to follow, please check the link below for all the Rules and Laws that are in effect in your neck of the woods and it also links you to some of the Best Places to Fly in your area… Also, if you travel on vacation, visit friends, and relatives in other parts of the country, check back here so you do not run afoul of the law.
Lift off, 6- feet (2-meters) or so, hover a bit, check the controls (move the drone a bit forward, back, left, right, yaw left and right). By now, your Controller will probably report again, Home point Updated.
Below is the link to all of the downloads offered by DJI for the Mini 3, including the User Manual.
Fly On and Fly Safe…
Welcome to the forum! :)
Thank you LoudThunder, I will check the map.
Yes I have registered all three, I have my Trust, CBO in order and drones are labeled with Pilot Iinstitute stickers.
I am enrolled in PI’s 107 course and several more when I finish this one
I have started some flying drills of squared, ovals, figure 8 and such, slow and easy is the key.:)
I am a proud Polo Shirt wearing PI Graduate and could not recommend it more highly. I am also active on the "Pilot Institute Drone Student Group" on Facebook… I also enrolled in the UAS course certificate program at my local community college. It was fun hanging with a lot of like minded folk.
Hi guys, I am new to drones, I am from the DFW area of North Texas. I am retired and have taken up drones to add to my hobbies.
I have a Mini 3 and a Mavic 3.
I also have 1 other drone.
Welcome to the forum from the Colorado Rocky Mountains. Happy and safe flying!
PilotOne
