Howdy! Greetings from Vilnius.
RSi
Vilnius, Lithuania
Last year I got my hands on a used, original Mavic Mini one and i loved it!
Now considering Mini 4 or Air3. Feeling intrigued about photogrammetry, trying to learn the basics.
Any leads on photogrammetry (mapping, 3d) greatly appreciated.
Just found out this site - it creates point clouds and 3d representations from your photos or videos for free.
Created by @superstate with Luma, just so that you could get an idea, footage was crappy, so is the model.
Few of my videos:
Youtube1, Youtube2, Youtube3
Use the
Photos/Video Section to post your videos
Welcome to the forum! :)
Since you live in Lithuania , there are specific laws and rules for you to follow, please check to ensure these are current.
Plug in your phone/tablet into your controller; turn on the Controller and DJI Fly App (if it does not start on its own…). On the Drone, open the front legs, then open the back legs, and then remove the Gimbal Cover.
Lift off, 6 feet (2-meters) or so, hover a bit, check the controls (move the drone a bit forward, back, left, right, yaw left and right). By now, your Controller will probably report again, "Home point Updated."
Below is the link to all of the downloads offered by DJI for the Mini, including the User Manual.
Fly On and Fly Safe…
Welcome to the forum. We look forward to your participation and your view of the world.
Ano passado comprei um Mavic Mini original e usado e adorei!
Agora considerando Mini 4 ou Air3. Ficando intrigado com a fotogrametria, tentando aprender o básico.
Qualquer pista sobre fotogrametria (mapeamento, 3d) é muito apreciada.
Acabei de descobrir este site - ele cria nuvens de pontos e representações 3D a partir de suas fotos ou vídeos gratuitamente.
Criado por @superstate com Luma , só para vocês terem uma ideia, a filmagem ficou uma porcaria, a modelo também.
Alguns dos meus vídeos:
Youtube1 , Youtube2 , Youtube3
ficaram lindos seus videos, mas que frio por ai... O futuro chegou entregas com drone delivery o futuro chegou
Reactions: LoudThunder
Pleopard
