Howdy
Welcome to the forum! :)
Hello, brand new member from London, UK!
Since you live in the UK, there are specific laws and rules for you to follow, please check to ensure these are current.
You don't mention if you are new to drones too, but in your other postings you ask about surveying your "island" in the Med… Just be aware that the island may be yours but it is probably in anther country's Airspace and you will be flying in their airspace, not yours… So check the requirements to fly legally there…
Plug in your phone/tablet into your controller; turn on the Controller and DJI Fly App (if it does not start on its own…). On the Drone, open the front legs, then open the back legs, and then remove the Gimbal Cover.
Lift off, 6 feet (2-meters) or so, hover a bit, check the controls (move the drone a bit forward, back, left, right, yaw left and right). By now, your Controller will probably report again, "Home point Updated."
Fly On and Fly Safe…
Hey LoudThunder,
thank you so much for taking the time to reply, some really good advice in there!
Let me just be clear: I don't 'own' an island in the Med (otherwise I'd probably have my own airplane, forget the drone!) 😂
I have registered with the authorities in the UK and in the EU, so there will be quite a lot of stickers on my aircraft - it took me 3 hours yesterday just to get my head around the regulations...
Sorry, I misinterpreted what you wrote in your other posting, "I have to survey a small piece of land (about 2 acres) on an island in the Med."
In the late '70s, I was in the US Air Force stationed in Italy with NATO. I had an Italian friend who owned a whole island in the Aegean Sea (off the East coast of Italy) with its own fishing village there and everyone there was his tenant… He seldom collected the rent and when he did, he usually pumped it right back into the village… His wealth came from a small steel factory.
We became friends easily because I had a job with NATO and so many Italians only wanted to be his friend to get a job and I liked him because those same Italians were constantly pestering me to buy them cigarettes, liquor, or stereos… We wanted nothing more than friendship from each other…
Now, if you fly FPV with your drone, you can pretend that you are in that "Airplane"… L 😁 L . . .
Reactions: wjkrysak
That sounds like quite a story! I better try and get myself a steel factory, or a FPV headset! 🤣
Reactions: LoudThunder
FNG_
