i know we cant speak of such things..........
cruzroy
but this really needs to be removed from firmware, ""DJI KILL SWITCH""
So you think having the ability to stop it on purpose should be removed.
Sorry but I disagree . He did it on purpose .
001041o047ik717cfmgm70-jpg.17833
yeah thats and accident waiting to happen...........yes that was the dji test, and i dont think you have a need to turn off bird at high altitudes.....REALLY!!
Yea REALLY. I know where your trying to go with this and it's not .
You want to hack your bird you know where to go and talk about it and it's not here . A CNC is there for a reason and needs to be .
no i think it something DJI should remove, did i say hack?? WOW......when the phantoms 1 thru 2 vision had naza, there was a bunch of drones i worked on that during high speed left and down maneuvers called helix or spirals,,,,, crashed to there deaths during flight due to shutdowns, so DJI fixed in a NAZA v2 firmware, caz they thought it would never happen....
"""A CNC is there for a reason and needs to be""" and on what planet do you need to death your drone at high altitudes.......not being and ***, but give an example
sorry i missed that.......................its CSC "Combined Stick Command" not CNC
and DJI does not replace drone if you do by accident, its all store in dat files
Old qute from another page, and there many like this, this was ollder version of CSC, and it was not a good idea either......
Well, it appears it happened to me today while I was practice flying at my RC field.... I have flown RC planes and helicopters for years. Never expected the motors to shut down when I pulled bottom left on both sticks doing some aggressive flying. Motors shut down at about 100' in the air and fell out of the sky like a rock and ended up severally damaged. Hope DJI will repair or replace. Not sure if I held the stick position in this place for 3 seconds or not, but if you’re in climb and reverse directions, the aircraft probably did not have time to recognize it was falling before it shut down. Not a good emergency shut down application in my opinion, why not just install a kill switch on the transmitter instead of using the throttle control at all??? For a helicopter or drone, motor shut down is a critical issue. Maybe even a flip cover on the kill switch like the fighter jets use on bomb releases as a second protection from accidental shut down. Would hope they address this issue, as I would call it a software problem as the drone was definitely still in a rotation motion, but possibly not in a vertical motion.
did i say hack??
Not exactly but your title is
And that's all you cant post about and you know it.
Think you just gave yourself an example .
Thank-You I stand corrected .
top 10 things that cause DJI drone to crash.........................wow whats number one.....sorry now being an ***
1. CSC in the mid-air (Combination Stick Command)
The newbies favorite way to crash the drone by pulling the sticks to the down inner corners \ / or outside corners / \ and stop the motors
Solution: Never do this movements on a sticks while in the mid-air, unless in case of emergency
2. Propeller shoots off
Of course the self-tightening props is a great invention of humanity, but some of the users only slightly push it till it stops to turn and think that it’s enough, which brings aircraft to shoot the props off on a high RPM
Solution: Never let the propellers loose on a motor. No matter if you are using self-tightening props or quick release props, always make sure that every propeller sits tight on a motor before taking off.
3. RTH Crash
You shooting the beautiful building (tree, hill, tower etc.), and flying behind it for the better shot, suddenly you lose the RC signal, because the building got on the way between the aircraft and the remote controller. So automatic go-home function turns on and your aircraft crashes into that building on a way back home.
Solution: Set your return to home altitude higher than any obstacles (trees, buildings etc.) in your area.
MC settings> Advanced Settings> Failsafe mode
4. Auto landing far from home
Once your aircraft is out power, you will get low battery warning and 10 seconds to cancel the RTH. After canceling the RTH you still can keep flying, but once your battery will hit the critical battery level, aircraft will start auto-landing. Pilot cannot cancel the landing, but the roll, pitch and yaw are still controllable. That’s a good luck if it lands on an opened spot, but if there is a trees or water… you know…
Solution: Go back home straight after low battery warning, don’t force your drone to fly till it’s totally out of power.
5. Flying out of sight
Flying out of sight is pretty dangerous, because all you can see is the video from the aircraft, which limits your view of the environment and can bring pilot to the altitude or direction misjudgment. Also it raises the chances to crash into the objects hard to see through the FPV, such as power lines.
Solution: Do not fly out of the sight if you are not familiar with flight environment.
6. Watching FPV and flying backwards
Everyone likes to do some beautiful shoots like this, but flying backwards we don’t see the way aircraft is moving to, so it’s extremely easy to crash your drone into the other objects on the way. It’s like walking backwards without watching the way.
Solution: Do not stare at the screen all the time, watch your aircraft and flight environment.
7. Indoor flight
Very often flying indoors due to the low GPS signal aircraft can drift, so it is getting difficult for the non-experienced pilot to control it.
Solution: Exercise your ATTI mode flight skills outside, to get the proper feeling of how to fly the aircraft without GPS
8. Failsafe and gain the altitude
As all we know, when the aircraft is out of the 20 meters radius from home point in case of low battery level, it will ascend to the failsafe RTH altitude and then go home. So some of the pilots are getting the low battery warning and go land their aircraft manually without canceling RTH. But since the aircraft is out of the 20m radius from thehome point, at that very moment before drone touches the ground it lifts up automatically to the failsafe RTH height, and flies to the home point. This makes a lot of pilots’ panic, so some of them start to do some odd stuff like CSC, and eventually crash their drones.
Also, aircraft can hit the obstacle above it, such as (tree branches, roofs etc.) while automatically raising up.
Solution: 1. Keep calm, your aircraft is not flying away
2. Land close to the home point
3. Cancel the low battery RTH andland manually.
9. Bad environment
Well, the bad environment is a reason of the huge part of the crashes.
What is bad environment? Metropolis full of skyscrapers or any surrounding of the high buildings, Power stations,TV stations, Mobile towers, high voltage lines, any sources of signal or electromagnetic interference.
Solution: Fly in an opened space, far from the buildings, power line towers and all those places described above.
10. Braking distance
Flying aircraft at the full speed is a great feeling, but sometimes you can meet obstacles on a way, that you can crash in just because it’s too late to brake.
Solution: Same as a car, aircraft has its own braking distance, so keep it in mind. It’s better to start soft braking earlier than make an emergency stop with a risk of crash.
Be aware and fly safe!
Reactions: iMario and gigamike
truth, i dont now what to talk about any more, ive been modding drones so long, i sould build my own, DJI started as tinkerers
another accidental CSC kill switch on a PRO........................yeah is well needed, sorry my mistake.....CFG file 56879.DAT
SHHHHHHH dont tell anyone.......i wont have nothing to ***** about
ralph.smith.mckenzie@gmai
