Yes, I was done with it, then light bulb came on to make a video.
Too bad, good thought come later
Thank you very much for clearing that up. I am interested in keeping a good video feedback on my crystal sky monitor. In a earlier post a user mentioned that the flight is limited by the battery so having antennas to make your drone go 6miles makes no difference if you can only get 5miles from.the batteryWell, my mod itself not increasing anything. I just applied some improvements to already excellent antennas.
IF you want to know how FPVLR antennas better over stock antennas, it all depends what you trying to do with it.
If you flying open sight, your stock antennas will outperform your battery flight time.
You really starting to benefit out of aftermarket antennas when you ether increasing your flight time with battery mods or, flying around obstacles like building, trees and such.
It's all depends on your application you use your drone for.
I am doing testing as we speak, should have video out by the end of this weekend with reports.
I will test stock, against ALFA patch antennas vs FPVLR and let you know.
I will do tree penetration, behind house obstacle penetration and open sight tests.
I got my amps on order also, so week after next more tests, same antenna set BOOSTED, eah baby
Here is the antenna comparison video
