Introducing Shane H from Western Australia
Welcome to the forum, from Hauptmann in North Texas!
Lots of Aussies (including many from WA) among our 150,000+ membership! We all enjoy helping each other learn and grow as pilots and photographers. Any time you have a question, just ask!
Glad to have you with us!
Rich R (aka Hauptmann)
I'm here to learn and hopefully become a better drone pilot. I'll take a look around and see you in the chats.
Since you live in Australia, there are specific laws and rules for you to follow, please check to ensure these are current.
Even if you may have flown Drones before, here is some Good Old Fashion Advice…
If you have a drone, let us know what you are flying and we might be able to hook you up with some great links… If yu have not yet decided what to buy, then "strap yourself in" as you are in for a fun ride…
Fly On and Fly Safe…
Hello all. Thanks for having me on board what looks like a fantastic forum. I'm here to learn and hopefully become a better drone pilot. I'll take a look around and see you in the chats. Cheers!
Welcome to the forum.
WA is a great state to own and / or fly a drone.
I've driven lot of the Baxter Cliff coastline, and outback highways up through the middle to the Pilbara, and want to explore a lot more over there some day.
Hello from the Crossroads of America Shane H
Welcome to the Forum. :cool:
Welcome to the forum. We look forward to your participation and your view of the world.
Saikiran Villa
