New from Culpeper, VA
Welcome to our forum, Chad, from Hauptmann, in Hurst, Texas!
You'll love the flexibility of vantage points an aerial camera platform affords--you'll get shots and videos you could only dream of before! I fly a Mavic 2 Pro now, but will soon add a Mini 3 Pro to my “fleet”.
We have over 150,000 members—many from your part of the South--who enjoy helping each other get the most out of our hobby. Most of the questions you'll have will’ve already been addressed, and are easy to search. If you have NEW questions, just ask!
I've attached a couple of links below, which will make learning piloting and photo/video skills easy. The author specifically refers to the Mini 3 Pro, but his “moves” apply to any drone (DJI, anyway).
Glad to have you with us!
Rich R (aka Hauptmann)
https://www.youtube.com/watch?v=c1j9VqmDYEI&t=497s
https://www.youtube.com/watch?v=vK6s2hJLRRE
new pilot from Culpeper VA running a Mavic 3 Classic. I'm looking forward to learning more about the do's and don'ts of the hobby.
1sr "Do…"; Do learn all you can, it's that much more enjoyable…
1st "Don't"; Don’t' stop learning, the rules and laws are changing and you'll be a better pilot if you know them…
As a New Drone Pilot, there are a couple of Legal Things you may need to do…
If you have not already done so, you will need to get your TRUST Certificate. You can get that at the Pilot Institute Web Site (FREE…) . Your Drone weighs more than 250-grams (0.55 pounds) and while you are flying under The Exception for Recreational Flyers, you are required to register your Drone.
When I first started flying I registered my Mini 2 because the TRUST Certificate and FAA Registration established me as a "certified" Unmanned Aerial Vehicle (UAV) Pilot.
If you are considering acquiring your Part 107 License, here is a link to get you going…
Since you live Virginia, there are specific laws and rules for you to follow, please check the link below for all the Rules and Laws that are in effect in your neck of the woods and it also links you to some of the Best Places to Fly in your area… Also, if you travel on vacation, visit friends, and relatives in other parts of the country, check back here so you do not run afoul of the law.
Lift off, 6- feet (2-meters) or so, hover a bit, check the controls (move the drone a bit forward, back, left, right, yaw left and right). By now, your Controller will probably report again, Home point Updated.
Below is the link to all of the downloads offered by DJI for the Mavic 3, including the User Manual.
Fly On and Fly Safe…
I appreciate the welcome as well as the links. Thank you!
I appreciate the information, very helpful for sure. I've already acquired my TRUST Certificate and may consider the part 107 license in the future.
All of the Culpeper area is Class G Airspace, no restrictions, no airports, no military bases, a real "Free for All…" So, unless there are local rules or laws about flying your drone, you have no restrictions…
Here is a video on YouTube...
Pleopard
