New member and new drone pilot
I recently bought my first DJI: Mavic 3 Classic.
Since you live in Italy, there are specific laws and rules for you to follow, please check to ensure these are current.
Plug in your phone/tablet into your controller; turn on the Controller and DJI Fly App (if it does not start on its own…). On the Drone, open the front legs, then open the back legs, and then remove the Gimbal Cover.
Lift off, 6 feet (2-meters) or so, hover a bit, check the controls (move the drone a bit forward, back, left, right, yaw left and right). By now, your Controller will probably report again, "Home point Updated."
Below is the link to all of the downloads offered by DJI for the Mavic 3, including the User Manual.
Fly On and Fly Safe…
Hello,
As my first drone I was thinking a lot between this and the Air 3. Then I chose the Mavic 3 Classic and I'm very happy even though I know I need to do a lot of pratice before before I felt confident flying anywhere other than huge meadows in the countryside.
Hello,
Welcome!!!! good advice. If you do not feel comfortable doing something don't. it takes patients. enjoy the sport. Keep your propellers up and your landing gear down.
Tally Ho!!
Doc Lemieux
Hello,
Welcome aboard, you'll find this forum to be an extremely friendly and helpful place 👍
Saikiran Villa
