IOS GO4 4.1.22 is now available. ...
Anthony
UK
Apparently there is a new version of GO4 4.1.22 out for IOS ....
What's New in Version 4.1.22
Spark:
- Optimized device connection and activation
guide.
- Added support when simultaneously downloading
firmware updates for both the aircraft and remote controller.
Phantom 4 Pro:
- Added Panorama mode (with v01.05.0300 firmware or
later).
General:
- Added compatibility with iPhone X.
DJI GO 4 on the App Store
And nothing for the Mavic. All risk, no reward.
It has been reported on the DJI forum that the mpp had some extra battery information ..... not sure if this is correct as I don't use IOS devices.
iPhone X....? Looks the same and still doesn’t use all the screen. :-/
View media item 1505
It has changed. The video area is slightly bigger (uses full height) and uses more width. But obviously the ratio of the iPhone X screen isn’t 16:9 so the video will not fill it all. Also need some screen for the controller to clamp on.
Can you confirm if the battery information has changed in this version ???
It was said that there was extra battery information displayed.
Also in map view it seems to use the curved edges.
This is the battery and map info I see on the app
Yes. - map is full screen with curved edges
swaggyC
