I have a mini 5.
No app crashes, no lag. Zero issues.
Yes, I have that enabled.Did you have your video caches enabled in the app?
Yeah I was saying 16gb of overall ipad storage memory. I think my video cache was set to 2gb but I will have to double check again. I stopped using it when it crashed multiple times in a row and my battery was getting low. More in-depth analysis of the issue today with everything charged up.The mini 4 has 2G memory, the mini 5 has 3G memory.
If you mean storage space, mine has 64G and I have 55G free.
Thanks, I will check the 1080p option but as I recall I had that setting set to "normal" and not 1080p.I use my ipad mini 4 for all of my flights. I can't stream to the controller in 1080p for more than a few minutes before the ipads gpu gets overloaded and I get a black screen. Turning off this option gives me no problems.
How about the brightness?I have a mini 5.
Previously used a phone but it seems bright enoughassuming you previously used the 4?
How is your device lag? I have the mini 4, I do experience slight lag at times. I've not ever had a dropped screen, or app crash.Hmmmm... IPad mini 4, 128 gig, video cache on at 4 gig, no problems, no dropped screen, no Go 4 crashes.
I'm hesitant to invest in the 5, but I suspect it's performance will be even better than the 4 with a stronger processor, an additional gig of RAM, longer battery life and an 11% increase in brightness. I think it will fire up both itself and the DJI GO 4 app more quickly.
I don't think the 128 gig metric matters as that is storage.
