I've used one for months... it does not have to be cellular.e
Will the Mini 5 WIFI only work or does it need to be cellular also?
I have the WiFi only version and all of the features work except, I believe, if you wanted to set a new home point other than where the aircraft took off. Eg if you were on a boat or moved elsewhere and wanted the aircraft to RTH to you instead of the original homepoint. Normal RTH works fine as the aircraft knows its own start location l, and although I haven't tried it, I believe activetrack relies on visual rather than GPS tracking. Someone else may be able to confirm.And the active tracking and return home button features work?
ThanksI have the WiFi only version and all of the features work except, I believe, if you wanted to set a new home point other than where the aircraft took off. Eg if you were on a boat or moved elsewhere and wanted the aircraft to RTH to you instead of the original homepoint. Normal RTH works fine as the aircraft knows its own start location l, and although I haven't tried it, I believe activetrack relies on visual rather than GPS tracking. Someone else may be able to confirm.
