I am new to drones and a Lot of my pics are thumbnail and i would like to be able to see them in a bigger format. Any help would be appreciated.
What you are probably seeing is the cached images stored on the mobile device. The high resolution images and videos are stored either in the SD card or the drones internal memory (depending on how you have it configured). Remove the SD card from the drone and insert it into a computer with a memory card reader or power on the drone and plug it into a computer using the USB-C cable to access the original pictures/videos.We have the same problem. Were you able to find the setting to fix it?
I found that if you are looking at them in a phone that is the problem. Once you put them on a computer or a tablet. It works fine.We have the same problem. Were you able to find the setting to fix it?
