Is this some kind of interference for my Mavic Pro drone?
d18
Please help and thanks.
The recorded video was fine before I calibrate the forward sensors to 1280x729 (my old PC display) instead of higher resolution.
Unsure whether sensor calibrations would cause this?
I will re-calibrate my drone using MacBook air 13" which I repaired this year after tea damage.
If you are talking about the black stripes in the sky, those are called Zebra stripes and show overexposure. You can turn them off in Go 4.
how do you turn it off? guess I need to google it. thx for the quick reply.
Tap the green toggle switch for on/off
Stop the video at 30secs and the Overexposure switch is clearly labelled.
The full video
Edit; some settings require everything connected and powered on. Even sdcard inserted!
Reactions: d18
ok and thanks, am going to turn it off and try flying again
quang_do
