It shames me to confess this...but here I go...
Hello from Goleta, California.
I purchased a Mini 3 Pro for checking ocean water clarity from above, and for finding the ever shrinking kelp paddies along the Santa Barbara coast and surrounding areas. I've alway been only so so at judging viz and it seems to me that my old and new dive buddies are even worse than me! At 58, I'm done being the bird dog. Throwing on a wet/sandy suit then swimming through mirky water, then doing it all over again. From now on I'm sending up my drone (just got my Trust Card) and getting a Birds Eye view. If you're in my truck when I say the viz is bad...and you disagree! I'll throw your gear out the window and you can call an uber! Not really, but if this works as well as I think it will, I'll be doing more diving and less hiking. I'm sincerely grateful to this community for allowing me to join. I look forward to learning about the different adjustments and filters available for looking into water.
Sincerely,
Lickity Split. AKA Bob
Welcome to the Skies
Sincerely,
Hi Bob,
Welcome to the group.
Doing what you are attempting is not Recreational flying. I am not trying to be a know it all, I just took a Part 107 class and passed my Remote Pilot Cert.
As per the FAA, recreational flying is only for “fun”, as soon as the INTENT changes to flying to accomplish a task, it becomes a Part 107 requirement.
I am not the drone police or a MrKaren, just wanted to provide the correct information..
Good luck, fly for fun.
Sincerely,
Invest in a decent or good circular polarizer to cut the glare and reflections down significantly, especially when shooting water. Look for CPL filters that combine ND filters for maximum flexibility if you're going to be shooting video. In a nutshell, using the correct ND filter allows you to set your shutter speed to twice your video framerate to minimize jitter in moving videos. If you've ever watched moving video that seemed jittery, that's why. If you're shooting 30FPS video, you want your shutter speed to be 60. If shooting 60FPS, you want your shutter to be 120. The ND filters let you reduce the amount of light coming into the camera to hit that sweet spot.
Sincerely,
Welcome! Just a friendly reminder, you’ll need more than a TRUST cert if your drone flying is for commercial or institutional purposes. 😉
Welcome! Just a friendly reminder, you’ll need more than a TRUST cert if your drone flying is for commercial purposes. 😉
100%. Anything, and by anything they mean ANYTHING other than recreational flying requires a 107 cert. If you're going to use the footage or drones abilities for anything other than recreation regardless of making money or not, the FAA requires certification. It's totally worth getting certified for the education and ability to use drones for more than a hobby. 😁
As a new owner of the DJI Mini 3 Pro, you might be intererested in a FREE Deep Dive Course on your New Drone Offered by PilotInstitute… They offer many other course, some Free and some for a Fee. All are great!
Since you live in California, there are specific laws and rules for you to follow, please check the link below for all the Rules and Laws that are in effect in your neck of the woods and it also links you to some of the Best Places to Fly in your area… Also, if you travel on vacation, visit friends, and relatives in other parts of the country, check back here so you do not run afoul of the law.
Lift off, 6- feet (2-meters) or so, hover a bit, check the controls (move the drone a bit forward, back, left, right, yaw left and right). By now, your Controller will probably report again, Home point Updated.
Below is the link to all of the downloads offered by DJI for the Mini 3 Pro, including the User Manual.
Fly On and Fly Safe…
Thank you Loud Thunder,
Lots of great advice. I just returned home from Switzerland Where I believe I got some great footage. My controller screen turned black with gray lines running through it and I'm just now getting a chance to try and figure this out. I really appreciate all of your good advice.
Sincerely, Bob
Reactions: RodPad
Your Mini 3 is still under warranty, even if you did not buy the Care Refresh, DJI will fix any issue you have fro free.
Support - DJI
You paid a lot of money for that drone, you are not alone and I've had great luck with warranty support in the past and they even sent me a New Drone with extra spare propellers for my inconvenience…
Good Luck!
Support - DJI
Good Luck!
I sent it back. Thank you for the information.
Sincerely,
Belated welcome (I've recently joined te group). That sounds like a super plan and I hope it has been effective. Has it? Viewing through the glitter and reflection of the surface must be a task indeed. I've used a cross-polarising filter on my Nikons in the past but I've no idea how that works (if it works) on a drone camera. If it does I might get one. Perhaps a suitable coloured filter might work and b&w photography ...just passing thoughts!
I have a dodgy knee but have to do a regular 'recce' hike to check out future routes for our club. But it occurred to me a drone could maybe do the tricky or highest parts. I wonder if I could do the whole walk from the comfort of the car, lol. All the best to you checking your kelp....Terry
  • Wow
Reactions: LoudThunder
Hi Bob,
But I’m having fun doing it.
Reactions: Meta4
Welcome from Brenham TX. I went to school at UCSB (many decades ago), and lived for a while after in Isla Vista and Goleta. We would both surf and dive off the coast. Some of my best diving was the Channel Islands off Santa Barbara.
Enjoy!
Reactions: MA2 317
FNG_
