Litchi 'active obstacle avoidance' ?
Fleek
Litchi has an AC setting called 'active obstacle avoidance' which dodges objects moving toward the Mavic (says the Help explanation). This is different from collision avoidance which stops at an obstacle in the path of the Mavic.
What object would be moving toward the Mavic other than perhaps a bird or another drone? Anyone tested this or know more about it? How far would it go in actively dodging an approaching object?
It doesn't change the on-board function of the Mavic's OA sensors. No matter how it's worded ~the function of the Mavic's sensors are coded into the firmware on the drone itself. So treat it the same as the Obstacle Avoidance in DJI Go4.
Thanks
Reactions: Qoncussion
deepdark
