Loosing video connection
dkpilot
Hi Fellow members,
I am new to drones and have had my Mavic for 1 week.
During that week I have had many issiue
s with the video being transferred to my iPhone during the flight, basically it looses signal. If I close the app and start it again then I get video signal again, it can last for the remaining of the flight or it will get lost again within seconds:-(
I am using firmware "v01.03.0900" could it be the firmware version or perhaps something else?
Regards from Denmark.
Kristoffer
It could be a problem with the cable connecting the iPhone to the controller. Try unplugging the micro USB from the controller, and connect your phone with a cable using the full size USB on the bottom of the controller.
I had exactly the same problem (with the same message on screen), and a cable change sorted it. I now only use the micro USB port for charging the controller.
Do you put the iPhone in aeroplane mode when you fly? I used to get this all the time but now I close all background apps and go to aeroplane mode and it's always been 100% reliable.
Reactions: dkpilot
The new cable sorted it out so all is good now, thx for answering!
Do a factory reset with assitant 2 and calibrate IMU, compass, Gimbal, etc, if that don't work revert to previous firmware.
Reactions: dkpilot and sstolk
And reset all DJI Go 4 settings after reset Drone to factory settings.
Reactions: dkpilot
EwaKrzyzanowska
