Lost signal
John Gibson
Hi, just flew 3 times today and every time I reached 1200 away I got a lost signal message. Any ideas?178C38EC-948E-4578-A8E1-D6C7B3B2A620.png
Ummm...don't fly so far?
Can't really see any of the flight path terrain from the photo posted.
If there is something your near that is either blocking the signal in the direction your flying or some other source of interference, that may not be obvious, your range will be limited. Even if you flew here before and had better range, there still could be some change that's causing signal loss. Try another more clear location and see if the problem clears up.
Sometimes you do have to gain some height to keep signal past 1500 ft if you do not have a good line of sight.
Phantomrain.org
Gear to fly your Mavic in the Rain and Land on the Water.
Joe Duhr
