- Joined
- May 27, 2017
- Messages
- 14,458
- Reactions
- 19,471
- Location
- Los Alamos, NM
- Site
- www.mavicpilots.com
Here's what I've found out as of today experimenting with LNPs with a Mavic Pro mfg'd on 28 Sep, 2017 and running the latest firmware (v01.04.0100). The a/c performs great out of the box with stock props; vid/pic quality is stunning; zero gimbal issues.
In all I've tried three different sets of LNPs, and each set has caused abnormal gimbal vibration. Two sets were ordered directly from DJI (gold tips and platinum tips). One set was ordered from Amazon (vendor is HiBlok). I was curious whether the issue might be related to mfg or vendor, i.e., something in the mfg process. While the vibrations appeared to be a bit worse with the HiBok props, the results were the same overall regardless of mfg.
I'd initially reported the issue to DJI via chat with Support. I reluctantly followed DJI's recommendation to refresh the firmware because they said they'd programmed in a fix in this latest version to address this anomaly. As I suspected before following through, the refresh made no difference whatsoever.
Note: On each flight where the issue was encountered the wind has been less that calm. In fact, it's been variable each time with gusts up to 10-20mph. Standing close to the Mavic it's obvious both visually and audibly that the high winds exacerbate the problem. I've yet to have a windless day to test the props. In all cases except the HiBloks, the issue went away once I got out of hover and started flying around, though it will return in gusty conditions where the motors are compensating for wind pressures.
I'm baffled by reports from forum members with seemingly similarly aged Mavics having mfg dates close to mine who report no issues since they're bound to have the same build components onboard their Mavics. There shouldn't be much variability from blade to blade in a mfg process, but the odds of having one propeller out of four that is slightly off weight wise or malformed is not astronomical. At these RPMs I wouldn't think it would take much of an error before it's noticeable.
That certainly adds to the somewhat contradictory body of data on this issue. I've tested the new props quite extensively on my early MP running 0400 firmware. No warnings at all, but I have noticed that low-light images show some motion blur that is not present with the original props and supports the hypothesis of more gimbal vibration.
