WheelzWorld
- Joined
- Mar 6, 2017
- Messages
- 227
- Reactions
- 68
- Age
- 38
I need to go down a mine-shaft-like lava formed, 20ft diameter pit crater. If I MacGyver'd the Lume Cubes to the forward prop arm will the Mavic be able to carry them? Any balance issues?
J
When I say "cold" I mean very white (not natural) as compared to "warm" more yellow like the sun.
I was hopping there is an option in the app for this...
I see they offer diffusers but does that helps with that or only diffuse the light?
I'm really on the edge of buying it... just can't decide between 1 vs 2 units...
It doesn't mount directly to the battery. Here are some pictures. I flew it around tonight for about 5 minutes. Very stable. Very impressed. I'll fly it for long distance in the next couple days but I'm very impressed with the mount and if you want to mount your Lume Cubes to your Mavic this is the place to buy it.
Could someone repost the link? I can't seem to find it.
You will be fine. Once you get about 40 feet from the bottom those Lume Cubes will light it up. I promise you. Send us the video on what you find!Okay, ready ro fly. I have my Lume Cubes mounted on a makeshift bracket attached to the wrap around ImpConcepts adapter. I am also using the Freewell prop guards and landing gear. I did a simple manual take off and landing with no issues - the winds were too high to go further.
Next week (I hope) it goes down the lava vent. I do not know, but guess, most of the radio signal comes off the bottom of the Mavic and I will be 'looking down' on it as it desends. Will I get enough bounce and scatter to stay in contact? It's all a guess.
The pit crater is about 20ft wide at the top and shouldn't vary too much going down. A rock-and-string measurement put the bottom - or ledge, at 85ft. What's down there? Probably just goat and sheep bones; we will see. Wish me luck.
(photos were quick grabs in the wind)
If you had let me know I could have made that downward facing plate for you out of plastic, it would b strong enough. The holes could be integrated into the main adapter also. You would just need to cut the screws to size.
Here is mine. Perfect fit!Yes! The mounts work great for the Lume Cubes! ImpConcepts has them for above the Mavic and for hanging on the side. Side probably works best.
Contact them here: DJI Mavic Pro Multi Purpose Top Accessory Adapter Clip (Standard & Enhanced)
Gary
Where's the video of the lava tube?
