MASSIVE FAILURE AFTER UPGRADING TO THE LAST FIRMWARE, PLEASE HELP
Hi, on Tuesday I upgraded my Mavic Pro 2 to the latest version with DJI assistant.After that I had a “system warning “ on my controller. Then the DJI Go app report EMU failure and compas Failure. To this point I tried to run all the calibrations unsuccessfully, I can’t initiate any calibration. In the DJI assistant I refreshed the updates, however the problems persist. I can’t calibrate the sensors through the DJI assistant nor the app....please help me!!! Thanks.
Reactions: SteveLeBigMac
Thanks brett was in another thread and getting slow on the draw .
Almostcowboy gun shooting smiley.gif;)
Reactions: brett8883
Ok forget the the remote calibration for now, never a bad thing to do though.
And did you calibrate the IMU in the DJI Go 4 App?
I can’t , because the diagnostics wouldn’t start. The same for calibrating the compass.
Cool thanks. Your IMU isn’t communicating with your main board. We need to try to jump start it.
Connect your phone to the remote and then turn on your bird and start the remote like normal. In the first screen in the DJI Go app there is a button with three lines on it in the upper right corner. Click that.
Then click academy
And then enter simulator.
Fly around for a minute in the simulator. Then land and exit simulator. Turn off the Mavic and then remove the battery. Reinsert the battery and power back up and see if that does it.
The idea here is that when in the simulator the IMU is bypassed and when you exit the simulator there’s a command sent to turn on the IMU that was turned off when in the simulator.
Last thing will it let you calibrate the gimbal?
Reactions: pvs
Reactions: WAXMAN and dirkclod
sachefp489
