Mavic 3 Enterprise - mp4 gps location WITHOUT using .srt file
TR14
Midwest
Does the Mavic 3 Enterprise embed a gps location in the mp4 file (like the P4P does) when the VIDEO SUBTITLES option is turned off in the DJI app.
Update: We toggled "Video Captions" OFF. NO .srt file was created. However, NO gps coordinates were included in the mp4 metadata.... Very frustrating.
NO .mov option either.
I know it works because my clients requires it for my job mission. They are used for insurance clients.
It may work on the Mavic 3 Cine.
It definitely doesn't include any gps data in the mp4 metadata from the Mavic 3 Enterprise.
Below is the metadata from an mp4 created by a Mavic 3 Enterprise
ExifTool Version Number : 12.10
File Name : DJI_20221013103657_0004_V.MP4
Directory : C:/
File Size : 304 MB
File Modification Date/Time : 2022:10:13 11:45:18-05:00
File Access Date/Time : 2022:10:13 16:01:11-05:00
File Creation Date/Time : 2022:10:13 11:45:01-05:00
File Permissions : rw-rw-rw-
File Type : MP4
File Type Extension : mp4
MIME Type : video/mp4
Major Brand : MP4 Base Media v1 [IS0 14496-12:2003]
Minor Version : 0.2.0
Compatible Brands : isom, iso2, avc1, mp41
Media Data Size : 317738679
Media Data Offset : 512
Movie Header Version : 0
Create Date : 2022:10:13 15:36:57
Modify Date : 2022:10:13 15:36:57
Time Scale : 30000
Duration : 19.25 s
Preferred Rate : 1
Preferred Volume : 100.00%
Preview Time : 0 s
Preview Duration : 0 s
Poster Time : 0 s
Selection Time : 0 s
Selection Duration : 0 s
Current Time : 0 s
Next Track ID : 4
Track Header Version : 0
Track Create Date : 2022:10:13 15:36:57
Track Modify Date : 2022:10:13 15:36:57
Track ID : 1
Track Duration : 19.25 s
Track Layer : 0
Track Volume : 0.00%
Image Width : 3840
Image Height : 2160
Graphics Mode : srcCopy
Op Color : 0 0 0
Compressor ID : avc1
Source Image Width : 3840
Source Image Height : 2160
X Resolution : 72
Y Resolution : 72
Bit Depth : 24
Color Representation : nclx 1 1 1
Video Frame Rate : 29.97
Warning : [minor] The ExtractEmbedded option may find more tags in the media data
Matrix Structure : 1 0 0 0 1 0 0 0 1
Media Header Version : 0
Media Create Date : 2022:10:13 15:36:57
Media Modify Date : 2022:10:13 15:36:57
Media Time Scale : 30000
Media Duration : 19.25 s
Media Language Code : und
Handler Description : DJI dbgi
Gen Media Version : 0
Gen Flags : 0 0 0
Gen Graphics Mode : ditherCopy
Gen Op Color : 32768 32768 32768
Gen Balance : 0
Meta Format : dbgi
Handler Vendor ID : Apple
Encoder : DJI DJIMavic3 Enterprise
Cover Art : (Binary data 435682 bytes, use -b option to extract)
Handler Type : Metadata Tags
Image Size : 3840x2160
Megapixels : 8.3
Avg Bitrate : 132 Mbps
Rotation : 0
-- press ENTER --
Below is the metadata from an mp4 created by a P4P
File Name : DJI_0075.MP4
Directory : C:/
File Size : 282 MB
File Modification Date/Time : 2022:10:13 14:54:46-05:00
File Access Date/Time : 2022:10:13 16:02:54-05:00
File Creation Date/Time : 2022:10:13 14:54:28-05:00
File Type : MP4
Major Brand : MP4 Base w/ AVC ext [ISO 14496-12:2005]
Minor Version : 2013.10.18
Compatible Brands : avc1, isom
Media Data Size : 296143623
Media Data Offset : 44
Create Date : 2022:10:06 12:33:32
Modify Date : 2022:10:06 12:33:32
Time Scale : 30000
Duration : 0:00:39
Preferred Rate : 1
Preview Time : 0 s
Poster Time : 0 s
Current Time : 0 s
Next Track ID : 3
GPS Coordinates (err) : 32 deg 53' 21.84" N, 96 deg 42' 0.70" W, 24.3 m Above Sea Level
Speed X (err) : +0.60
Speed Y (err) : -0.20
Speed Z (err) : +0.00
Pitch (err) : -9.70
Yaw (err) : -43.60
Roll (err) : +3.30
Camera Pitch (err) : -27.80
Camera Yaw (err) : -41.20
Camera Roll (err) : +0.00
Comment : DE=None, Mode=P, DSW=0001
Category : v01.08.1719, 1.3.0, v1.0.0
Model : FC6310S
User Data mux (fr) :
User Data mux : ))..
Track Create Date : 2022:10:06 12:33:32
Track Modify Date : 2022:10:06 12:33:32
Track ID : 1
Track Duration : 0:00:39
Track Layer : 0
Image Width : 1920
Image Height : 1080
Op Color : 0 0 0
Source Image Width : 1920
Source Image Height : 1080
X Resolution : 72
Y Resolution : 72
Compressor Name : AVC encoder
Bit Depth : 24
Media Create Date : 2022:10:06 12:33:32
Media Modify Date : 2022:10:06 12:33:32
Media Duration : 0:00:41
Handler Class : Media Handler
Handler Type : NRT Metadata
Handler Description : .DJI.Meta
Gen Flags : 0 0 0
Gen Graphics Mode : srcCopy
Gen Op Color : 0 0 0
Gen Balance : 0
Meta Format : priv
GPS Coordinates : 32 deg 53' 21.84" N, 96 deg 42' 0.70" W, 24.3 m Above Sea Level
Speed X : +0.60
Speed Y : -0.20
Speed Z : +0.00
Pitch : -9.70
Yaw : -43.60
Roll : +3.30
Camera Pitch : -27.80
Camera Yaw : -41.20
Camera Roll : +0.00
Image Size : 1920x1080
Megapixels : 2.1
Avg Bitrate : 60.2 Mbps
GPS Altitude : 24.3 m
GPS Altitude Ref : Above Sea Level
GPS Latitude : 32 deg 53' 21.84" N
GPS Longitude : 96 deg 42' 0.70" W
Rotation : 0
GPS Position : 32 deg 53' 21.84" N, 96 deg 42' 0.70" W
-- press ENTER --
Not sure what TR14 is doing but default options on my freshly received M3E .srt files with captions enabled work just perfectly like my mavic 3 cine would. Its recorded to an .SRT file exactly the same.
Thanks, solagraphy. I was hoping the mp4 files would have the geodata embedded in the actual mp4 file (like the P4Pv2) and not on a secondary .srt file.
Andrefu
