Mavic 3 Pro and RC Pro Update
No sure, but may have lost mine... and cant test at the mo, due to weather.
Updated from .0200 to .0500. RC Pro.
Hello all,
I also dared to update to .500 today.
DJI RC Pro / MA 3 Classic
- From 03.02.0200 with active hack FCC 1.4 (Drones was on 01.00.0400).
- RC Pro updated via DJI Assistant to 03.02.0500
- RC Pro left on
- RC Pro FCC 1.4 reinstalled
- Re-Start RC Pro => FCC 1.4 is active again
- Afterwards drone on 01.00.0500 Update
- FCC and additional options (for example LED off) still active
Happy Landings :cool:
Reactions: GrimtheViking
Hello all,
- RC Pro left on
That's right, this fcc hack works on 0500. but honestly, if I compare the hack with the hacks from Drone-Hacks, those from DH are simply nicer and better. There they have the button for the aux lamp, for example, just sitting there. now you have to give custom commands to turn the LED on or off. How cool it would be if they could activate the button again, just like DH. so much easier
Yours show CE mate. Have you tried installing the hack again with DH app?
Yep, tried upgrading, downgrading and reinstalling still no joy, Sincoder installed now and all good again. Easy install and works brilliant. Just need one for the Evo2...
Reactions: Suren
I doubt anyone managed to get the Autel hack has yet, would be good though
lost my hack too and I can't apply the hack as the DH app does not recognize this version. Will try downgrading first.
But your'es shows the same as the image on the first page so you still have fcc?
I am also experiencing problems with DH FCC hack on RC Pro, even on the supported FW .0200.
Does anybody have a update or have the same experience on this issue?
The DH patch worked fine on my controller with V03.01.0200 for a long time here in EU, but FCC was gone after I upgraded (by a mistake) to v.0500.
I reverted to V03.01.0012 on the RC Pro to be able to reapply the hack via DH-win-v1.35. After that I upgraded to V03.02.0200 (latest in Bird map) but the FCC mode is still gone. Tried this process twice, still no success.
Is the DH hack also confirmed to work with latest RC Pro FW .0500?
My Air 2s drone is on FW 02.04.2500.
Not sure if you fixed this but have you tried going in the RC settings - Apps - Dji Fly - then delete updates - roll back RC FW to 03.01.0012 - apply hack - update to FW 03.02.0200
Thanks for your input. My RC Pro hasn’t been in use for two months, but today I tried a new reflash according to your input. I deleted app updates first and downgraded via 03.01.0500 before going further down to 03.01.0012 and up again to 03.02.0200 - and it worked, I am now in FFC mode. I don’t know if it was the “delete app updates” or “via 03.01.0500” who did the trick, but I am happy.
However, is there anybody running the RC PRO 03.02.0500 firmware or latest .0700 successfully with FCC mod from Drone hacks?
I had the same issue after updating to 0700 and deleting the app updates etc is what worked for me. Now FCC does not work past 0200 for me.
Good to hear you are at least back in FCC mode. I have just updated to the latest .700 and reinstalled the latest Sincoder and all good in FCC mode.
Reactions: Suren
Hi Suren, Merry Christmas to you and yours hope you had a nice one.
The hack works Ok, everything in the app is all good also,.
Easy download of link after payment, have to run install a couple of times.
But yeah for me its all Ok, and support is there when needed and he's prompt following Dji updates,
but once installed that's it. Signal strength is so much better once in FCC..
InspectorTom
