Mavic 3 Pro + optimal controller config
bog_pilot
Canada
Hey all. New to be Mavic 3 Pro owner and new to piloting drones.
For those who use the DJI RC, can you mirror the screen / cast it somewhere for others to watch as well? Was hoping to do some flights near my folks house and to throw the live feed on their tv or a laptop.
I did some digging and found that the 'fly more combo' shows the M3 Pro combined with the RC pro controller and 3 batteries - but the cost goes up significantly and I was hoping not to have to spend all that extra.
I cannot help you with the sending the imagery from your controller to your TV, but that has come up recently in the forum, try searching on various criteria. If you do not find what you are looking for, go to YouTube, if it can be done, it has been done there…
Another point, I believe you typed up your message in a word processor and then pasted it into the Forum's edit box. I think that is why there are three spaces between each paragraph. I use MicroSoft Word to type up all my responses in all my writing, be it email, texts, or even this response to you…
Word is so much easier to format your writing, spell check, and even save your topics for future reference… However, if you copy and paste it directly into the Forum's edit box, you get those extra spaces. To avoid that, I copy and paste the response into Notepad and then then copy that text and then paste it into the edit box… If this is so, try it… If not, please ignore my "insane rantings…"
Since you live in Canada, there are specific laws and rules for you to follow, please check to ensure these are current.
Plug in your phone/tablet into your controller; turn on the Controller and DJI Fly App (if it does not start on its own…). On the Drone, open the front legs, then open the back legs, and then remove the Gimbal Cover.
Lift off, 6 feet (2-meters) or so, hover a bit, check the controls (move the drone a bit forward, back, left, right, yaw left and right). By now, your Controller will probably report again, "Home point Updated."
Below is the link to all of the downloads offered by DJI for the Mini 3 Pro, including the User Manual.
Fly On and Fly Safe…
Welcome to the MavicPilots forum. Enjoy safe and happy flying!
Update:
The Mavic 3 series can use the DJI RC N1, DJI RC, and DJI RC Pro.
I found a new DJI RC N1 online with a user who got a replacement and didn't have use for the extra controller. These can be had for relatively cheap, can use an android device which ultimately can cast to another device such as Chromecast. Can use an LCD TV in the back of my pickup truck (utility plugin) and chromecast. (My android phone can act as a wifi hotspot between the devices.
This is a much cheaper alternative than spending $1400 on the DJI RC Pro. The only downside is that I optimally need a dedicated tablet for my screen as I don't like using my phone. Most tablets have a dull screen, nits wise. The more costly Samsung tab S8, the ipad mini or the really costly tripletek tablets are brighter (tripletek boasting 1300 nits, compared to the RC Pro 100 nits, or RC 700 nits. Most tablets I've noticed are around 400-500 nits of brightness and I tend to fly on sunny days (as do most).
Still decisions to be made but at least I've solved the issue of casting the Mavic 3 series without needing to spend a lot of money on the RC Pro.
Also passed my the advanced RPAS field review (Canadian requirement to do advanced flight operations). Good times.
Reactions: LoudThunder
dronesforlife
